How to Finish the "Other Programs" in MLB The Show 26 for Bonus Stubs
FireSoul
1er Frischling
Beitrag von FireSoul »
What Are “Other Programs”?
“Other Programs” is a catch-all category in the game for challenges that don’t fit neatly into the main Missions or Conquest modes. They typically involve smaller tasks, such as completing a series of innings with specific players, hitting certain types of home runs, or pitching a set number of strikeouts. The rewards are usually bonus stubs, sometimes player cards, and occasionally special packs.
These programs can seem small individually, but they add up quickly, especially if you focus on completing multiple programs at the same time.
How Do I Access These Programs?
You can find “Other Programs” from the main menu under the Programs tab. Once inside, you’ll see a list of available tasks along with their requirements and rewards. Some programs are time-limited, while others are permanent. It’s important to check them frequently to avoid missing deadlines, especially for programs that reset weekly.
Which Programs Should I Prioritize?
Not all “Other Programs” are equally valuable. Here’s a breakdown of which types are worth focusing on:
Stub-focused Programs: These programs directly reward stubs for completing a challenge. They’re the most straightforward way to increase your currency.
Player Collection Programs: Some programs reward player cards that can be sold on the market. While it requires an extra step, selling the player often yields more stubs than the direct reward.
Hybrid Programs: These programs provide both stubs and items. They are useful if you need a mix of resources, but you should evaluate whether the item is worth keeping or selling.
Generally, if your goal is to earn stubs efficiently, stub-focused programs should be your top priority.
How to Complete Challenges Efficiently
Completing “Other Programs” is mostly about planning and focusing on efficiency. Here’s how to approach it:
Check Requirements Before Playing: Each program lists the exact requirements. Some are simple, like “Get 10 hits in Domination,” while others may require using a specific player or position. Make sure your roster matches the program’s needs before starting.
Stack Challenges Where Possible: Many programs overlap. For instance, hitting a home run in a specific stadium might also count toward a hitting challenge. Keep track of overlapping requirements to make every game count toward multiple programs.
Use the Right Players: If a program requires specific players, make sure they are in your active lineup. Don’t waste time trying to meet program requirements with players who won’t count.
Play Short Games for Quick Progress: Not every program requires full nine-inning games. You can often complete innings-based or stats-based programs in shorter games, which saves time while still progressing.
Track Progress Daily: Some programs reset weekly. Even if you can’t finish everything in one session, make it a habit to log in and chip away at them daily.
Specific Tips for Popular Program Types
Pitching Programs: Focus on strikeouts, groundouts, or complete innings. Using pitchers with strong ratings in the required stats makes these challenges much faster.
Hitting Programs: Look for programs that require extra-base hits or specific types of contact. Adjust your swing timing and approach based on the program. For example, power hitters are better for home run challenges.
Defensive Programs: These often involve fielding a number of outs cleanly. Place your best defensive players in the field and consider simulating innings if the program allows it to progress faster.
Selling Program Rewards for Maximum Stubs
After completing a program, you often get items or players that can be sold on the market. Selling them efficiently can sometimes be more profitable than taking the stub reward directly. Monitor the market to determine the best time to sell and always check if the player or item fulfills any of your team’s needs before selling.
If you ever find yourself short on stubs but want to skip the grind, you can also buy MLB 26 stubs ns from legitimate sellers. This is especially useful if you’re close to finishing a set or need a specific player to complete a program quickly.
Mistakes to Avoid
Even experienced players make errors that slow down progress. Here are the common pitfalls:
Ignoring Requirements: Playing without checking the program’s requirements is the fastest way to waste time.
Not Using Optimal Players: If a challenge requires a certain skill set or player, using the wrong one will mean repeated attempts.
Skipping Programs: Some small programs can be completed in minutes. Don’t ignore them, as they add up over time.
How Many Stubs Can I Expect?
“Other Programs” vary in rewards. Simple programs may give a few hundred stubs, while more complex ones can provide thousands. If you focus on completing several programs daily, it’s possible to accumulate a significant amount of stubs each week. Many players find that finishing all “Other Programs” regularly allows them to buy mid-tier players or packs without spending real money.
Finishing “Other Programs” in MLB The Show 26 is a practical way to earn bonus stubs and improve your team. The key is to prioritize stub-focused programs, plan efficiently, and take advantage of overlapping challenges. Even small programs, completed consistently, can build up a meaningful advantage over time.
By paying attention to requirements, using the right players, and tracking your progress daily, these programs can become a reliable source of stubs. And remember, if you need a quick boost, you can always buy MLB 26 stubs ns to supplement your progress without disrupting your gameplay rhythm.
