Sandworms in Dune Awakening are a constant and formidable threat on the open desert. They can kill instantly and cannot be combatted by any amount of armour or skills. The only options for survival are to remain undetected and outrun them when discovered. This central challenge adds a unique strategic depth to exploration and combat in the game Dune Awakening Solari.
When you step on the open sand, a vibration meter appears on your screen showing how much noise you’re making that attracts Sandworms. The longer you create vibrations, the closer and quicker the worms appear. That’s why movements like sprinting or jumping are risky—they dramatically increase vibrations.
The best tactic I found is to stay low and slow. Crouching reduces vibration significantly, letting you spend more time on the sand before worms appear. Using stealth to cross sandy areas makes exploration less nerve-racking and allows for calculated risks, especially if you are hunting resources or approaching crashed ships.
Electronic equipment such as shields or levitation tech is a double-edged sword—it helps in combat or travel but attracts Sandworms even from above the ground. Turning off these devices before crossing sand reduces your signature and chance of attack.
If a Sandworm surfaces near you, noise no longer matters. It instantly locks on your position and charges. The only hope is to sprint to rocky terrain or a safe location as fast as you can. Using vehicles or grappling hooks (if available) can save precious seconds, but always remember the worm is faster and will catch you eventually if you hesitate or are too slow.
Drumsand patches—red sand areas—make extra noise when crossed, so avoid them if possible to keep vibrations down. Specialized gear and items can sometimes reduce vibrations below normal levels, but these are rare and require good knowledge and preparation.
By mastering stealth movement and speed tactics, Dune Awakening players can make even the vast, hostile deserts feel conquerable. It turns the looming threat of Sandworms from frustrating invincibility into thrilling suspense and cleverly planned adventure Dune Awakening Items.
Mastering Stealth and Speed in Dune Awakening to Avoid Sandworms
