Arc Raiders Converging Paths Project rewards revealed!
Verfasst: 26.06.2026 09:12
If you've been diving into Arc Raiders lately, you already know the Forgotten Relics event has been keeping everyone busy. But the real talk of the community right now is the Converging Paths Project. The full reward track for this limited-time relic-hunting challenge just got completely laid out, and honestly, the devs are giving us some pretty solid reasons to grind it out before the July 27, 2026 deadline.
Completing all six stages of the project locks in a massive haul of blueprints, high-tier gear, a decent chunk of currency, and some exclusive cosmetics to show off back at base. Here is a breakdown of what we are playing for and whether it is worth your time.
The Big Ticket Grand Rewards
Once you clear the entire run, these are the permanent unlocks and headline rewards hitting your inventory:
Surge Coil Blueprint: This is the big one. It gives you the permanent crafting recipe for the Surge Coil, which is easily one of the most powerful artifacts in the current meta. No more relying on lucky drops.
Sextant Backpack Charm: The main cosmetic attachment for the event so you can flex your completionist status.
Red-Black Saltwalker Outfit Color: An exclusive palette swap for the Saltwalker gear. It looks clean and definitely stands out.
300 Raider Tokens / Coins: This is the premium seasonal currency. You don't have to wait until the very end to get all of it either; it is distributed dynamically as you progress through the stages.
Step-by-Step Stage Rewards Breakdown
The nice thing about the Converging Paths Project is that it doesn't make you wait until the final hand-in to get a dopamine hit. Every single step dishes out a mixture of immediate survival gear to help with your next deployment alongside the premium currency.
Stage 1: Secure Safe Passage
A relatively straightforward start to get your feet wet. You'll grab some defensive utilities and your first pocket of coins.
Pulse Mine x3
Lure Grenade Trap x3
Raider Tokens x25
Stage 2: Collect Supplies
Keeping the momentum going with more tactical items to control the battlefield during extractions.
Smoke Grenade Trap x3
Explosive Mine x3
Raider Tokens x25
Stage 3: High-Value Scavenging
This is where things start heating up. On top of more tokens, you get an actual weapon drop to boost your firepower.
Blaze Grenade Trap x3
Jolt Mine x3
Rascal II Weapon x1
Raider Tokens x50
Stage 4: Relic Extraction
Stage 4 gives you a taste of power by handing over consumable versions of the meta artifact before you unlock the ability to craft it.
Surge Coil x3 (Consumable versions)
Explosive Mine x3
Raider Tokens x50
Stage 5: Fleet Enhancement
The penultimate stage focuses heavily on high-tier performance upgrades and utility items that can completely change how you approach a skirmish.
Combat MK.3 (Flanking) Augment x1
Photoelectric Cloak x1
Bobcat II Utility x1
Raider Tokens x50
Stage 6: Final Hand-in
The finish line. Turning in this final stage secures your permanent blueprints, the exclusive drip, and the largest single payout of premium currency.
Raider Tokens x100
Overall, it looks like an incredibly rewarding loop. Even if you aren't a hardcore cosmetic collector, getting a guaranteed blueprint for the Surge Coil is massive for anyone trying to optimize their endgame loadouts. Just make sure to get your extractions sorted and finish up all 6 stages before July 27. Good luck out there, Raiders!
Pulse Mine x3
Raider Tokens x25
Explosive Mine x3
Raider Tokens x25
Jolt Mine x3
Rascal II Weapon x1
Raider Tokens x50
Explosive Mine x3
Raider Tokens x50
Raider Tokens x50
Raider Tokens x100
