How to Get the Rare Banana in Grow A Garden 2
Enxbrdjmpm
1
Fahrzeug: 116i E8x
Beitrag von Enxbrdjmpm »
If you’ve been grinding away in Grow A Garden 2, you already know that hunting down Epic crops is where the real fun—and big money—begins. Among these high-value plants, the Banana stands out as an absolute prize. It’s an Epic crop that turns your plot into a long-term cash machine.
In this guide, we’ll break down exactly how to get your hands on this elusive seed, whether you have Sheckles to burn or want to hunt it down entirely for free.
How to Find and Buy Banana Seeds
The most straightforward way to secure a Banana seed is through standard commerce, but it requires a bit of patience and a healthy bankroll. Here is how you can track it down in the market:
Visit Sam's Seed Shop: Head directly to the center of the server map where Sam's physical storefront is located. If you are far away or busy tending to your plots, simply click the "Seeds" button at the top of your screen to teleport straight there instantly.
Wait for the Restock Cycle: Sam doesn't keep the same inventory forever. The shop refreshes its entire selection every 5 minutes, giving you a fresh batch of options to choose from.
Play the Rarity Odds: Because the Banana is an Epic crop, it isn't guaranteed to be on the shelves. It carries a 9% chance to appear during any given restock. You might need to camp out or check back multiple times before it finally rolls around.
The Price Tags: When it does appear, a Banana seed will cost you 30,000 Sheckles. Alternatively, if you are short on Sheckles or tired of waiting for the RNG restock timer, you can completely bypass the grind and purchase the seed instantly from the shop UI for 119 Robux.
The Alternative Free Method: Tracking Rob Robin
Don't want to drop 30,000 Sheckles or part with your hard-earned Robux? There is a brilliant alternative method built into the game that lets you acquire Banana seeds for absolutely nothing, though it requires a bit of map awareness and the right companion.
Keep an eye out for a special NPC bird named Rob Robin. This helpful bird occasionally flies around the garden map, visiting plots and snacking on ripe fruit left behind by players. When it eats, it drops free multi-harvest seeds on the ground—including the coveted Banana seed. Anyone quick enough can run over and grab them before they disappear.
The Owl Pet Synergy
To make this method reliable, you should ideally equip an Owl pet. The Owl has a unique passive ability: it will hoot loudly whenever Rob Robin spawns into the server. This audio cue gives you an immediate head start to look up at the sky, track the bird's flight path, and stand right under it to clean up the dropped loot.
Planting and Optimizing Your Yield
Once you finally get a Banana seed, the real reward begins. Unlike standard single-use crops, the Banana grows into a magnificent multi-harvest tree. This means once it matures, the tree stays firmly planted in your plot and will repeatedly grow fruit for you to harvest and sell over and over again, making back your investment split-lick.
To maximize your profits, you want to cut down on the growth cycle as much as possible. You can drastically speed up the growth process by stacking your utility gear. Placing a Common, Uncommon, and Rare Sprinkler together on your plot—combined with active watering from your watering can—will make your new Epic tree shoot up in no time.
