When Playground Games officially dropped Forza Horizon 6 and brought the festival to the neon-lit highways and mountain passes of Japan, the entire meta for straight-line speed completely shifted. We aren't just talking about top speed anymore. If you want to dominate drag strips, rocket out of slow-speed corners on mountain passes, or humiliate people at the highway intersection meets, you need pure, violent acceleration.
In this game, the 0–60 mph (0–100 km/h) and 0–100 mph metrics are everything. Let’s skip the marketing fluff and look at the absolute data-driven kings of launch and acceleration in Forza Horizon 6, along with the exact numbers that make them monsters.
The Electric Rocket: Rimac Nevera (2021)
Electric vehicles (EVs) have always had a launch advantage due to instant torque, but the Rimac Nevera in Forza Horizon 6 is on a completely different level.
Stock Power: 1,914 horsepower
0–60 mph (Tuned): ~1.40 seconds
0–100 mph (Tuned): Under 3.5 seconds
Because it sends power to all four wheels instantly via quad electric motors, the Nevera doesn’t wheelspin; it just hooks and flies. If you keep it in an S2-class build, nothing touches its initial 50-meter sprint. The downside? Like most EVs in the game, the acceleration starts to blunt slightly once you clear 180 mph due to its single-speed transmission setup. But from a dead stop? It’s an absolute cheat code.
The Drag Strip King: Chevrolet COPO Camaro (2018)
If your goal is to destroy the quarter-mile drag strip near the festival grounds, EVs won't cut it at the top end. That is where the COPO Camaro steps in.
Max Upgraded Power: 1,800+ horsepower (after a full engine swap and twin-turbo conversion)
0–60 mph (Drag Tune): ~1.35 seconds
Quarter-Mile Time: Sub-6.8 seconds
The secret to the COPO Camaro isn't just the raw power; it's the weight transfer. When tuned with full drag tires, a slammed rear suspension, and soft front springs, the front wheels will literally lift off the tarmac. The car hooks so violently that it beats the Rimac to 100 mph by sheer brute force, making it the undisputed king of traditional straight-line drag racing.
The Hypercar Legend: Koenigsegg Jesko (2020)
While the Jesko is technically famous for holding the highest top speed in the game (pushing past 310 mph with the right tune), people sleep on its rolling acceleration.
Max Upgraded Power: 1,600 horsepower (Stock) / 1,900+ horsepower (Fully Upgraded)
0–100 mph: ~3.8 seconds
100–200 mph: Insanely fast, under 4.5 seconds
From a standstill, the Jesko can struggle with rear-wheel-drive wheelspin. However, if you convert it to All-Wheel Drive (AWD) in the upgrade shop or use it for a "roll race" starting at 40 mph, its acceleration from 60 to 200 mph is the fastest in the entire game. It cuts through the air like a knife, making it the ultimate weapon for highway speed traps.
How to Finance Your Speed Obsession
Building these absolute monsters isn't cheap. A fully maxed-out drag or speed build easily runs hundreds of thousands of credits on top of the steep base price of the hypercars themselves. While grinding out wheelspins and seasonal events is the traditional route, many players who want to jump straight into high-tier tuning look for alternative shortcuts. If you want to bypass the endless credits grind to immediately buy these top-tier cars and engine swaps, you can find a reliable supply of forza horizon credits for sale via trusted third-party platforms like u4n to instantly load up your in-game garage.
The Sleepers: Forza Edition Cars
You cannot talk about acceleration in Forza Horizon 6 without mentioning the "Forza Edition" (FE) cars. Playground Games loves to give specific FE cars broken physics multipliers.
Vehicle Special Feature Best Used For
Toyota Trueno AE86 FE Absurd engine swap ceiling Mind-blowing roll-acceleration
Nissan GT-R Black Edition FE Boosted AWD launch grip Mid-tier drag lobbies & wet roads
For example, a fully built Toyota Trueno AE86 Forza Edition with a maxed-out engine swap can actually challenge the Jesko in mid-range acceleration due to its lightweight body frame and glitched power-to-weight ratio.
Summary Takeaway
For instant, brain-melting launches from a dead stop, buy the Rimac Nevera.
For dedicated drag racing where you want to see the front tires leave the ground, build a COPO Camaro.
For highway roll-racing and shattering speed traps, stick to the Koenigsegg Jesko.
Best Cars for Pure Acceleration in Forza Horizon 6
Enxbrdjmpm
- Forums Stöberer
- 1
- Fahrzeug: 116i E8x
