In Aion 2, the Defiance (also called Remove Shock) mechanic is a cornerstone of survival and DPS optimization in endgame raids. Defiance immediately breaks hard crowd control (CC) effects like knockdowns, air-binds, grabs, frost, and fear. On top of that, it grants Tenacity, a 5-second buff providing 100% resistance to status effects.
Mastering when and how to chain Defiance into your rotations is crucial. In high-tier raids, like Dying Dramata's Nest, strategically pairing Defiance with your burst or AoE abilities allows you to ignore boss mechanics, maintain uptime, and maximize damage output.
Tank Classes: Frontline Stabilization Combos
1. Templar: Defiance ➔ Iron Shield ➔ Provoking Roar
Best Used For: Full-screen knockdowns or boss tank busters.
Mechanic: Activate Defiance immediately after a knockdown to trigger Tenacity. Follow with your physical mitigation shield, then execute your AoE taunt. This ensures uninterrupted aggro control and protects your party without risking CC downtime.
2. Gladiator: Defiance ➔ Vengeful Strike ➔ Furious Cleave
Best Used For: Add-heavy phases or summoned high-threat objects.
Mechanic: Use Defiance to break CC and channel AoE attacks that are usually vulnerable to interruption. This maximizes life-steal and clears adds while maintaining boss pressure.
Melee DPS: Max Burst Combos
Assassin: Defiance ➔ Shadowstep ➔ Rune Burst Chain
Best Used For: Frontal cone attacks or restricted movement mechanics.
Mechanic: Assassins suffer massive DPS loss when interrupted. Trigger Defiance, then Shadowstep behind the boss and unleash your rune stacks. You can safely hit critical multipliers without worrying about micro-CC disruptions.
Ranged & Magic DPS: Uninterrupted Channeling Combos
1. Sorcerer: Defiance ➔ Ice Sheet ➔ Magma Typhoon (Long Cast)
Best Used For: Phase transitions with heavy AoE floor markers and tremors.
Mechanic: Long cast spells are susceptible to interruptions. Proactively trigger Defiance when minor CC hits, then use the 5-second Tenacity window to safely cast your highest-damage ultimates.
2. Ranger: Defiance ➔ Tactical Retreat ➔ Snipe / Ruin Arrow Volley
Best Used For: Rooted or slowed mechanics from bosses.
Mechanic: Break the initial immobilization with Defiance. Use backward mobility to create space, then unleash your full ranged burst rotation safely from maximum distance.
Endgame Raid Strategy Tips
Do Not Panic Cleanse: Defiance cooldown is ~60 seconds. Minor CCs without follow-up damage are often better left for a Cleric cleanse. Save Defiance for mechanics that can wipe your raid or tight DPS windows.
Avoid Buff Overlap: If a Chanter or other party member has active group immunity or casting-speed buffs, delay Defiance. Overlapping personal Tenacity with team buffs wastes defensive uptime.
Best Defiance Combos for Endgame Raids in Aion 2
LunarPhoenixX2
- Forums Stöberer
- 1
