U4GM - How to Build a Balanced Team for Raids in Aion 2
Verfasst: 17.10.2025 05:01
Raids in Aion 2 are some of the most challenging and rewarding content in the game, requiring careful preparation and team coordination. Whether you are tackling early endgame content or the hardest bosses, having a balanced team can make the difference between a smooth run and a frustrating wipe. In this guide, we’ll break down the key elements of assembling a strong raid group and offer tips from a seasoned player’s perspective.
Understanding Team Roles
Before assembling your team, it’s essential to understand the core roles needed for most raids: Tank, Healer, and DPS (Damage Dealers).
Tank: The tank’s primary job is to control enemy attention and absorb damage. A good tank can prevent the team from taking unnecessary hits and keep the fight manageable.
Healer: Healers sustain the team by restoring health, removing harmful effects, and providing buffs. Their contribution is often underestimated, but even a small mistake in healing can cost the raid.
DPS: These players deal the bulk of damage to the enemies. A well-coordinated DPS team can reduce the overall time spent on a boss fight, minimizing the risk of wipes.
Balancing these roles is crucial. Too many DPS without sufficient healing or tanking can lead to chaos, while too many support roles can prolong battles unnecessarily.
Choosing the Right Classes
In Aion 2, certain classes naturally excel in specific roles, but flexibility is key. For tanks, look for classes with strong aggro management and defensive abilities. Healers should prioritize sustained healing skills over burst healing for prolonged encounters. DPS classes vary depending on whether you need single-target or AoE damage.
Team Composition Tips
A classic raid team might consist of:
1 or 2 Tanks
2 Healers
4 to 6 DPS
However, some bosses require more specialized setups. For example, fights with multiple mechanics might benefit from an additional healer or a DPS with crowd-control abilities. Always research the raid mechanics in advance to adjust your team accordingly.
Communication and Coordination
No matter how strong your team is on paper, poor communication can ruin a raid. Using voice chat or in-game macros to signal cooldowns, interrupts, and positioning is critical. Assign roles clearly and make sure each member understands their responsibilities before the fight begins.
Gear and Consumables
Raid success depends heavily on gear optimization. Tanks should focus on defensive stats, healers on mana and healing effectiveness, and DPS on maximizing damage output. Consumables such as potions, buff foods, and special enchantments can turn the tide in difficult encounters. Some players even choose to buy Aion 2 Kinah to quickly upgrade their gear or stock up on consumables, and it’s important to use trusted Aion 2 Kinah sellers like U4GM to ensure safe transactions.
Practice Makes Perfect
Finally, remember that no team is perfect from the start. Learning boss patterns, understanding phase changes, and experimenting with different team setups will improve your raid efficiency over time. Don’t hesitate to adjust your team composition or strategy after each attempt.
By carefully balancing roles, choosing the right classes, and optimizing gear and consumables, you can create a team capable of tackling the most challenging raids in Aion 2. With patience and practice, even the toughest bosses will become manageable challenges.
1 or 2 Tanks
2 Healers
4 to 6 DPS
