Additionally, Infuse Weapon is exclusive to the Amazon Ascension and cannot be used by other classes. Its passive nature frees up skill slots while still offering a major offensive boost, making it a staple of POE2 Currency Amazon builds focused on elemental projectile damage.
Elemental Infusion Node: The Key to Infuse Weapon
The Elemental Infusion node not only grants the Infuse Weapon passive but also determines how it is activated. Here is the core mechanic described in the node:
When you expend an Energy Charge, you gain 2 Cold Infusion.
When you expend an Endurance Charge, you gain 2 Fire Infusion.
When you expend a Fury Charge, you gain 2 Lightning Infusion.
Once infused, your ranged weapon is temporarily empowered. The Infuse Weapon description explains:
“Imbues your weapon with enchantment. Making non-melee projectile attacks with this weapon consumes the infusion to infuse the fired projectile, causing it to explode at the end of its flight.”
This means players can create elemental explosions simply by firing arrows or lances—provided they’ve previously spent charges and gained the appropriate infusions.
Triggering the Infuse Weapon Effect
Activating Infuse Weapon involves a sequence of steps:
Generate Charges: Use a skill like Cull the Weak or any other means to build Energy, Endurance, or Fury Charges.
Consume the Charges: Skills such as Lightning Lance or Twister Lance consume these charges, triggering the infusion process.
Use a Projectile Skill: Finally, using a non-melee projectile skill while infused releases a powerful elemental explosion upon impact.
Each infusion lasts 15 seconds, and players can store up to six infusions of cheap POE 2 Currency each type simultaneously. That means up to six Cold, six Fire, and six Lightning infusions can be ready for deployment—allowing players to sequence or chain elemental attacks effectively.
MMOexp: How to Acquire the Infuse Weapon Skill in PoE 2
Florencehg63
- 1er Frischling
- Fahrzeug: 123d E8x
