U4N - Monopoly Go: 9 Dice Roll Tricks to Land on Key Spaces Consistently
freshlotuswave
1er Frischling
Beitrag von freshlotuswave »
Mastering Monopoly Go isn’t just about luck—it’s about strategy, especially when it comes to dice rolls. Whether you’re aiming to snag that rare Monopoly Go sticker or secure a crucial property, landing on key spaces consistently can make all the difference. Here are nine expert-approved tricks to improve your dice control and dominate the board.
1. Understand Dice Probabilities
Every number on two six-sided dice has a different probability. For example, 7 is the most common roll (6 combinations), while 2 and 12 are the rarest (1 combination each). Plan your moves around high-probability rolls when targeting key spaces.
2. Aim for the Utility and Railroad Spaces Early
Railroads and Utilities are high-value early-game targets. Since 5-9 are frequent rolls, position yourself 5-9 spaces away from these spots to increase your chances of landing on them.
3. Use the “Rule of 7” for Jail Avoidance
If you’re close to Jail, rolling a 7 could send you there. Adjust your position to avoid being exactly 7 spaces away unless you want to take the risk.
4. Time Your Rolls for Sticker Boosts
Certain events or Monopoly Go sticker bonuses temporarily increase dice rewards. Save your high-stakes rolls for these moments to maximize gains.
5. Target the Corner Spaces Strategically
Corners (Go, Jail, Free Parking, Go to Jail) are often overlooked but can be game-changers. For example, landing on Go right after passing it gives you double the cash.
6. Watch Opponent Movements
If an opponent is close to a key property, consider altering your strategy to block them. Sometimes, a defensive roll is smarter than an aggressive one.
7. Balance Short and Long Rolls
Mixing short (2-4) and long (8-10) rolls keeps opponents guessing and helps you adapt to changing board dynamics.
8. Prioritize Completing Color Sets
Once you own one property in a set, aim for the others by calculating the dice rolls needed. This methodical approach pays off in the long run.
9. Leverage the “U4N” Strategy for Late Game
In the late game, focus on monopolies and utilities. The U4N (Utility 4-Neutral) tactic involves holding Utilities while denying opponents complete color sets, forcing them into unfavorable trades.
Final Tip: Where to Find Rare Stickers
If you’re hunting for that elusive Monopoly Go sticker, check community forums or trusted marketplaces—just be sure to research the best place to buy Monopoly Go stickers to avoid scams.
