Ashes of Creation Gear Guide: Academus Monitor Faulds Explained
Enxbrdjmpm
Fahrzeug: 116i E8x
Beitrag von Enxbrdjmpm »
If you’re diving into Ashes of Creation and exploring the gear system, one item you might come across early on is the Academus Monitor Faulds. This guide breaks down what it is, how it works in practice, and what most players consider when equipping it. I’ll focus on real gameplay experience rather than hype or promotion.
What Are Academus Monitor Faulds?
Academus Monitor Faulds are uncommon heavy armor belts designed for mid-level players, usually around level 20. They have decent armor and stats for early combat, and historically in the game lore, they were worn by city campus guards before the Carphin invasion.
In practice, most players pick them up because they provide a good balance of strength, constitution, and physical defenses without being too expensive or difficult to obtain. For heavy armor users, they offer a solid starting point before moving on to rare or epic belts.
What Stats Do They Provide?
Here’s a breakdown of what you get with the uncommon version:
Armor: 122–126
Strength: 35–36
Constitution: 35–36
Physical Evasion Rating: 475–479
Physical Accuracy Rating: 12–24
Max Durability: 22
Required Level: 20
Item Level: 27
In general, most players wear these belts to boost survivability while maintaining some offensive stats. Strength increases melee damage, and constitution adds health and resistance. The physical evasion rating is particularly useful for avoiding hits in early dungeons and open-world PvP skirmishes.
How Do They Compare to Higher Rarity Versions?
Academus Monitor Faulds scale with rarity. Here’s how stats change as you move from uncommon to legendary:
Rarity Armor Strength Constitution Physical Evasion Physical Accuracy Max Health
Uncommon 122-126 35-36 35-36 475-479 12-24 -
Rare 131-139 38-40 38-40 482-486 27-31 7-20
Heroic 149-159 43-46 43-46 496-506 41-51 30-40
Epic 170-181 49-53 49-53 520-535 65-80 48-56
Legendary 194-220 57-64 57-64 551-586 96-131 65-83
Most players usually stick with uncommon or rare belts until they reach mid-game content. The jump in physical accuracy and max health at heroic and epic levels makes those higher-tier versions significantly better for group PvE and PvP, but they’re also harder to acquire.
How to Use Academus Monitor Faulds Effectively
1. Pairing with Other Gear
Most players combine these faulds with other heavy armor to maximize defense and survivability. While the belt alone doesn’t dramatically increase damage, it helps tanking or frontline builds stay alive longer.
2. Early Dungeons and Questing
Because uncommon faulds are easy to get and require level 20, they’re usually worn during early dungeon runs and solo questing. The combination of armor and constitution allows players to survive hits from multiple enemies, making progression smoother.
3. PvP Considerations
In general PvP scenarios, uncommon faulds aren’t particularly strong, but they still provide a defensive edge. Most players will replace them as soon as better gear is available because the physical accuracy bonus is modest. However, for low-level open-world PvP, they can give you just enough stats to hold your own.
Durability and Maintenance
The uncommon Academus Monitor Faulds have a max durability of 22, which means they will degrade relatively quickly if you’re constantly fighting enemies. Most players keep a backup belt or plan to repair often to avoid being caught in a dungeon with broken gear. Durability management is a practical skill in Ashes of Creation that many new players overlook.
How to Obtain Academus Monitor Faulds
In general, these belts are available from early quest rewards, loot drops, or crafting. Many players will craft them if they have a crafting character, as the stats are predictable and the materials aren’t rare.
For players who want to upgrade quickly or ensure consistent stats, some may choose to buy Ashes of Creation gold from U4N to fund crafting or trading, though this depends on server economy and personal playstyle. Most players still earn gear naturally through gameplay before considering this option.
Tips from Experienced Players
Don’t hang on to uncommon belts for too long. Upgrade to rare or heroic versions as soon as you can.
Check physical accuracy vs. evasion. For tank builds, evasion is usually more important, while melee DPS might prioritize accuracy.
Repair often. Broken belts are common in dungeons, and carrying a spare can save a lot of time.
Combine with constitution-heavy gear. This makes early combat less punishing.
Keep an eye on upgrades. Even if you craft your own, upgrading to rare or heroic versions is more cost-effective than constantly buying new uncommon belts.
Academus Monitor Faulds are a solid early-game heavy armor belt that provides a good mix of defense, survivability, and minor offensive stats. Most players wear them during early dungeons, questing, and low-level PvP. While they won’t carry you through endgame content, they provide a practical foundation for gearing up before moving on to higher-tier belts. Managing durability and planning upgrades is key to getting the most out of them.
